hi,
i like to convert multiple cad files to dgn files by batch process.
can anyone share the batch file/script.
Harikrishnan.R
What version (e.g. v10.x.y.z) of MicroStation, or other product, are you using?
hari krishnan said:i like to convert multiple cad files to dgn files
That's a rather open question. DGN files are CAD files. Be more specific. If you mean AutoCAD files, then say so, and tell us which version of AutoCAD produced those files.
Mstn has a batch convertor to do what you want look under help batch convertor ... FYI CAD doesnt mean autocad or even Mstn it stands for Computer Aided Design or Computer Aided Drafting..
Many hundreds of drafting,modelling and Design software packages exist and all of them can be called CAD software ... if you don't know the name of the source software then tell us the extension or format ie .dwg, .dgn etc you want to convert from too...
Lorys
If you are looking at Batch Converting DWG to DGN or vice versa. See this wiki for some quick steps.
https://communities.bentley.com/products/microstation/w/microstation__wiki/15340/how-to-convert-dwg-references-through-the-batch-converter
https://communities.bentley.com/products/microstation/w/microstation__wiki/8830/batch-convert-utility
Yes, converting DWG to DGN is a real common task. Lots of options for this, you want to get those sorted out before you run the whole bunch. You might also consider leaving them as DWG depending on your needs.
Thanks for this information. It useful
