Hi
I have created several MS CE11 deployments via the /layout option for various clients. Each time, when I install the software, the Windows 7 PC hangs. The PC is useless for the duration of the install, it locks up every application., I even get a dialog saying Microsoft Windows has stopped working
Has anyone else seen this.?
Ian
Hi Ian,
We created a deployment image here with MicroStation CONNECT Edition Update 11 and deployed it on Windows 7 Enterprise, Service Pack 1 and it installed correctly. Can you try to recreate the deployment image again to see if there might have been an issue when it was created?
Dan
I have only done one deployment install so far. Mstn CE10 was already installed on that machine. Everything worked well for me.
--Robert
Hello Ian,
Will you please send us installation log . it will help us to pinpoint exact issue.
Installation log can be found under C:\Users\......\AppData\Local\Temp
Thanks & Rg
Harshad
