I installed CONNECT 11if I click on the material editor, the program crashes
does anyone have the same problem?
ciao
Opened the Material Editor dialog in Connect Update 11 and it loads without a crash.
Kindly log a Service Request and share the exception logs. Check wiki How to quickly find and collect Exception logs and Minidump files
Is it file specific? If Yes please provide us the files so we can reproduce it at our end. ZIP the file and email us.Are you accessing the file from a network location?.
Hi Leonard, thanks for the replyI sent a request attaching the log
I tried with files on the net and in local, same problem
I tried with upf and ucf by default and with new file, problem persists
I also tried uninstalling update and re-installing the CE 11, nothing
thank you
Alex Martini said:if I click on the material editor, the program crashes
Like Leonard, I am able to open the Material Editor in Update 11.
What version of Windows do you have?
It's not crashing for me. But it is taking a long time to select a material if the thumbnail needs updating.
Hi Jon,
windows 7
