I have an issue regarding the clip volume is not function when i open A model. The clip volume setting in view attribute dialog are missing.
However, when i open B model, it's worked and clip volume setting in view attribute dialog are shown.
Both models are in DGN.
May i have some advise for this issue due to i have really no idea about it.
1. In A Model Situation
2. In B Model Situation
Thank you !
Hi Patole,
Thank you! BTW, is that any method to convert i-model to normal model which is supporting for clip volume?
I really hope that the clip volume can support to i-model, for us easy to reference and present the model perfectly through file exchange in i-model.
Hi Herman,
Herman Tan said:is that any method to convert i-model to normal model
to merge referenced i-model into empty DGN or to open i-model and to save as should work fine.
Jan
Is it possible to have a section cut view in i-model by Bentley view?
Thanks, Jan,
I will try it
Mahendra Patole said:If there’s sufficient interest, we can consider supporting clip volume in read only files but it will just clip the model & will not create drawing from it.
We need it big time... in Mstn and and the verticals sitting on top.
I would be wary of waiting for users to answer a poll. My experience is that a lot of projects just give up on Navigator and go with Navis because it is easier to use (the clip volume thing being a good example of why) especially when dgn is not the dominant / client mandated format... inspite of all the advantages of converting from dgn to i.dgn compared to dgn to nwc.
