The attached file has an arc with points placed along it using the point along elements tool. In V8i SS3 I can snap to these points for example when using smartline. In Connect I can't. As far as I can tell snap settings are the same.points.dgn
Mr D
I have tested this and I too have the same. It appears if the points are on a line, then they do not snap, if the points are in free space all is OK. As a test I moved your arc and tried it again and this time Smartline tool was able to pick the points.
Ian
Thanks Ian. That explains why tentative snap works but that's not a good answer for my users.
Duncan
100% agree. I even looked at the accusnap elements. points is not one of them. So it is something in CE that has changed (in my opinion)
I tried priority too just in case but no difference. Add it to the list
I was able to get accusnap to snap to the points but it is very sensitive and wants to go to the keypoints of the Arc if I twitch.
~HTH
John.
yep
