What's the philosophy behind solids and associative dimensioning?
If I draw a solid and add associative dimensions, these dimensions are updated when I change the size of the solid.If I add a feature (like fillet or cut) to this solid, and then add an associative dimension, this last dimension is not updated when I change the size of the solid.Assoc. Dimensions placed before adding features still work as expected.
Regards,Andre
Hi Andre,
this is an issue with the association that affects parametric solids. We are working on it as we speak and will be fixed in Update 12.
R,
Marco
Hi Marco,
Thank you for the explanation.
Andre
