Geographic Projection in Microstation
Hello
In regular Microstation, I am trying to set up a file with the geographic projection WGS1984. I have been able to do this and set my coordinate readout to be lat and long. When I attach a geolocated jpeg, it is in the wrong location and it is the wrong size. Does anyone have any idea as to why this is? Also, I am able to draw a line between 2 points with keying in point acsabsolute, I used 0,0 and -89 deg, 42deg. When I change the linear units from degrees to feet or survey feet, distances are wrong. Measuring a distance from one end of the line to the other is very short, it measures about 60 feet. The working units are set at 8000 per inch. Doe sanyoen know what the best working units are to get these distances to be correct?
Thank You
CS
  • the geo jpeg you sure its got the right cords ...are you able to see the  jpg settings in the raster manager  ie xyz and scale is there a jgw file to accompany the jpg  this has coord information
    Lorys
    click link to PM me
Reply
    Lorys
    click link to PM me
