Hi guys!
Is there any way to turn off fit view when I doblu click on middle button?
What version (e.g. v10.x.y.z) of MicroStation, or other product, are you using?
Currently the 10.10.00.23 Microstation PowerDraft Connect
Hi Rona,
This is associated with the setting for the XButton 1. What ever button acts as your XButton 1 will cause a View Fit if it is double-clicked.
You can change the button which acts as you XButton 1 thru the Button Assignments Remap Buttons option. This will affect all assignments that rely on the XButton1.
Hi Rob!
I've tried to change the Middle Button to e.g. XButton10 and now the the XButton1 means the Button12 in the Remap Buttons. In the Button Assigment there is no action on the XButton1 and still with the double click on the Middle Button cause fit view. I think the problem is connected with the pan drag command, because when i delete it from the Button Assigment the problem solved, but I can't pan. :D
Gergely Róna said: I think the problem is connected with the pan drag command, because when i delete it from the Button Assigment the problem solved, but I can't pan.
I am afraid it's "all or nothing" situation, because click and double click are procesed by the same code, so when "pan drag" key-in is associated with XButton1, the same key-in is used to process XButton1 double click.
BTW May I know why do you want to switch off the double click fit all feature?
With regards,
Jan
