> [Sameer Khan] no option to upload
When editing your post, use the Insert|Insert image/file/video menu.
Looking at the images you provided to explain your issue it appears to be a graphics display issue. Which version of MicroStation V8i? What version of Windows? This type of information can make a difference in providing answers to issues like these.
https://communities.bentley.com/products/microstation/f/microstation-forum/87312/read-first-microstation-forum-best-practices
The following Wiki should help you to investigate what issues might be associated with your problem but I would suggest to ensure you have the latest driver for your graphics card and the system meets the minimum requirements.
https://communities.bentley.com/products/microstation/w/microstation__wiki/13543/troubleshooting-graphics-display-issues
https://communities.bentley.com/products/microstation/w/microstation__wiki/4175/microstation-v8i-system-requirements-and-hardware-recommendations-tn
Hi Sameer,
please, a subject should be short and clear, it's not the place where the whole question should be written.
I agree with Andrew it's probably caused by graphic driver, these problems were discussed in several times in the past. For better understanding of your situation, you should share at least:
Check the links provided by Andrew, they contain more information how this issue can be solved.
With regards,
Jan
