Should named presentations work with clip volumes?
I have a door panel in 3d that is set to show only in an isometric view but still shows in a top view with a clip volume applied.
Yes, Named Presentation should work with Clip Volumes. At present only Named Presentations Model, Top and Front are working fine and not rest of the others...we have a Defect-803583 reported earlier to track down this issue.
Thanks Dinesh. I really like the functionality that named presentations should provide but it seems very glitchy and unpredictable.
Thanks for the feedback Duncan. The feature it's still in Tech Preview status so all glitches found will be logged and planned for a prompt fix.
Marco,
I am also finding NP's very buggy... to the point that it is not clear how we are supposed to use them.
1. Some vids showing what the proposed workflow looks like would be very helpful.
2. Hopefully, there will be an interim build before U12. It will be difficult to 'debug' the tool without a reasonably working build to test drive.
Yep agree totally with this. I was hoping to set up a test file to demonstrate how NPs would work in conjunction with perforators but it's just to buggy and unpredictable to even attempt that at the moment. I love what the tools are supposed to do and I know they are in beta but they feel more like alpha. They need to be far more robust and a documented workflow would be very helpful.
