I installed the latest version of MS CE on my computed and figured out that it is still wfully unstabile. The program terminates almost every time I try to open dwg files with it. I am able to use dwgs as referencies but can't open them for editing. V8i opens the same files without troubles.
I wonder do other CE users have more luck with dwgs?
Hi
Questions:
Have you customized CE at all ie created a central Workspace?
What version of DWG is it?
Do you get any errors?
Have you looked at the log files it produces?
Ian
Kindly log a Service Request and share the exception logs. Check wiki How to quickly find and collect Exception logs and Minidump filesPlease share a sample DWG file (Zip the file).
Yes, I have created a workspace for our company but it is quite simple - just line styles, layer names, cells etc. There are some old acad fonts and line styles in my resource list. I wonder will they cause conflicts with CE. They work fine with V8i.
Problem solved. I contacted Bentleys technical support and they asked me to tick 'Block Attributes as Tags' on.
It was too early to celebrate. I managed to open a couple of dwgs after I ticked 'Block Attributes as Tags' on but next time I opened the same dwgs my Microstation hanged again...
