Hi
I have a file with around 30 models in it. I would like to export the models to seperate files, so one model per file. Is it possible to do that in an easy way or do I have to export the model 30 times with only one model selected each time? (Running connect edition)
Regards,Robert
Robert
I presume you mean export to DWG!. If so, have a look at the Save as dialog, change the file type top DWG , then click on the Options.
Within the General tab, expand the Advance and then select the option Non-Default design Models nd change iot to 'Create Separate Files'
If its not DWG then let me know
Ian
It is a DWG and that exactly how I did my export. But still got a DWG-file with lots of models in it, see the bottom of the pictures with all the tabs:
Hi Robert. Those are sheet models not design space models presumably all referencing the same design space. You need to tick create separate files for sheets.
Answer Verified By: Robert Högberg
Aah, thanks. Must have missed that one. Is it possible to change the name to only the model name istead of the filename_modelname as it names it now?
Don't know of a way to do that. There are free file renaming utilities that will strip off the filename as a post export process.
