I wonder what is wrong when my text editor (MS CE upd11) is super slow?
Text appears to the editor a couple of seconds after I have typed tem with my keyboard. Editing a longer text paragraf is a total pain. Is this another 'improvement' in Connect Edition?
Hi Yrjo, is this happening with all files? Could you try with a fresh file created using one of the seed files delivered with Update 11?
I have plenty of gripes about Connect but I haven't experienced this problem. Do you have a test DGN then other could see if it is file related or something to do with your setup?
text editor demo.dgn
Here is one text sample. If I try to add text in the middle of the paragraf it takes roughly 2 seconds until the new text appears on the editor. V8i edits the same text fluently.
Thanks for posting the file Defect 972743 has been filed for review.
That has something to do with TrueType fonts. Whatever TrueType font I change the original font to it's awfully slow to edit.
If you change the font to, say, simplex, it works as fast as it should (in Powerdraft CE10).
