HI. Is it possible in Micro Station copy all object features to another object? For example I need to change lines type. And it takes equate long time to search right type from database. More easier would be to copy features from another line that has has the right one.
What version (e.g. v10.x.y.z) of MicroStation, or other product, are you using?
Vyacheslav Kostromin said:Is it possible in Micro Station copy all object features to another object?
If by 'object features' you mean element symbology then the answer is 'yes'.
Use MicroStation's Change Element Attributes tool:
Note the Eyedropper icon top-right. Use that to select an existing element. Then you can apply that element's symbology to another element.
use the Alt and LMB to match and make active the attributes symbology of the object you want to match then use the change element pallet tool to change the object that needs changing....
Lorys
I use Bentley map v8i. I have line 1, I need to make line 2 the same like line 1. Because line 2 was made in 3 D Win program and when I transfer in to Bentley map v8i like DWG it looks different. Bentley map v8i use own element codes. Now I do changing by "Adaptation"-"change to target" and than I suppose to found from the long list right category and code and than type and press change bottom. If I have example line 1 I can copy all the features to line 2 if it is possible in this program of course.
Hi. How does it look "change element pallet" or from which field to search it? I use Finnish version and both Finnish and English not my mother languages(
Answer Verified By: Vyacheslav Kostromin
Vyacheslav Kostromin said:I use Bentley map v8i
If you're using a GIS then doesn't the GIS feature type set the symbology of each element?
