Hi all,
If I add a toolbar button that runs the keyin "RASTER DISPLAY TOGGLE" to my custom menu dgnlib, why are all rasters attached with raster display of all views set to off and locked out?
The only way I can get them to turn on is by using the RASTER DISPLAY keyins and it happens without any use of the toolbar button. It also reverts to being all view display off and locked out on restart of the session (no matter what dgn I try).
I have observed this in v8i and all versions of CE - does anyone know why this may be happening?
Mark
Hi Mark,
this key-in is view independent and also does not rely on selection. It toggles display of all attached rasters. This is a different display mechanism then the view toggles found in Raster Manager. If you use "RASTER DISPLAY ON" key-in raster display should be restored after restarting a session.
If you want to control display by view, have a look at the following key-ins:
imgmanager display setoff
imgmanager display seton
Pascal
