I have a shapefile attached to a .dgn that comes in aligned perfectly when opened in V8i, but when I open the same file in Microstation Connect or Descart Connect, it's shifted way off to the northeast. I have tried detaching in Connect and reattaching, but it still comes in shifted. When I open it again in V8i, it comes in correctly. I have tried with and without a geographic coordinate system defined in the DGN.
Hi Jason,
I've verified attached dgn in both, MicroStation V8i and CE and observed the same result. i.e. shp files are shifted away in both versions.
I am requesting you to provide some more details (steps or a video clip) so that I can investigate it more.
Thanks for reporting,
Manoj
Hi Manoj,
Please see reply to Jan above. Thanks for your help, and please let me know if I can provide any more information.
Was curious, so I tried this. DGN with georeference, referenced shape file in the same part of the world. File came in with a scale of 3.28xxx, closed file reopened, now it's 1:1, and correct. Sometimes when I attached the shapefile, it might show 1:1 in error. Try checking/forcing your shapefile to 1:1, see if it doesn't align. Or simply attach, close, re-open.
Thanks for trying. For me the references come in at 1:1 every time in both V8i and CE. In V8i the shapefiles align with the dgn and in CE they're shifted to the northeast, with or without projection defined in the dgn.
That's what my CEr11 did the first time, shapefile was way up NE, subsequent tries and/or exit re-open seemed to fix it. Inconsistent, frustrating to diagnose.
I looked at your file its in us survey feet but no CGS coordinate system applied to it .. mstn cannot align other refs even shp files if your base file has no datum and coord system..., the shape files have prj files and you can read this with note pad and it tell gis and cad what the datum and projection is and units for the shp files... then microstation will reproject these to match the existing datum projection which yours does not have... I looked inside the prj files they both have the CGS NAD 83 HARN
so you can add a CGS to your active file even though your using survey feet and I can only see us feet in the prj in msnt assign a datum try CGS NAD 83 HARN this should then align all the files.. also your using display set I wouldnt when trying to test things as display sets force levels off etc....
Lorys
Hi Lorys,
whether GCS is assigned to master or not is not important in this discussion (despite of it's recommended), because it's about why the same file is displayed correctly in V8i and not in CONNECT Edition.
When there is not GCS used, references are attached 1:1, so there is no shift. When the same file is opened in another version, the result has to be the same and references cannot be shifted.
Moreover, when all all files uses the same GCS, it's not important whether GCS is used or not, so it likely not help in the discussion.
Jan
the shape file has a projection defined, how can mstn attach said file correctly without a cgs defined ?
And if one used the same projection for both dgn and shp this would help to remove some variables as the cause of it not working.
More over others have reported that it indeed shifts in CE using the files as supplied, again applying the same cgs that is used in the shp files should make it work correctly and no shift in either versions... so it would seem CE is misreading the prj file interpretation or the way msnt CE is reading where the data in in the dgn...
