Hello!
I am creating batch file to perform the following on each sheet file:
1: select plot frame from the reference file ( courtesy one of the threads on this forum)
# loading selectionby for one of the selection options#
load mdl selectby
place fence fromshape;
level element select file:referencefile.dgn framelevel
#trying several options without success in order to initiate choice of the element here#
choose selection
dx=0,0
selview 1
point ab
dl=0,0
selectionby execute
none of the options above create "left-click" effect that would place fence around my selected shape ( which is a single rectangle placed on specific level for the purpose of plotting)
After selecting this shape (manually at this point) I actually need to set fence mode to "VOID", as I would like to delete everything that is selected OUTSIDE of the frame
so, I cannot find the fence mode key-in that would switch fence selection to "void"
reason for above manipulations is, that I am trying to select and delete all tag sets that were double-and triple-placed, and to leave only one that is within the plotting frame. the other method of selection ( by "selectby") would not work in this case , as these tagsets are completely identical, and I will not be able to separate them by properties.
Thank you!
using: AECOSIM Buiding Designer V8i (Select Series 6)
Version 08.11.09.866
Denis Erlich said:so, I cannot find the fence mode key-in that would switch fence selection to "void"
A key-in chain to start fence operation, set the fence mode and to enter acceptation point:
fence delete;lock fence void outside;xy=#,#
With regards,
Jan
