Key-in string to select elements outside of the fence
Hello!
I am creating batch file to perform the following on each sheet file:
1: select plot frame from the reference file ( courtesy one of the threads on this forum)
# loading selectionby for one of the selection options#
load mdl selectby
place fence fromshape;
level element select file:referencefile.dgn framelevel
#trying several options without success in order to initiate choice of the element here#
choose selection
dx=0,0
selview 1
point ab
dl=0,0
selectionby execute
none of the options above create "left-click" effect that would place fence around my selected shape ( which is a single rectangle placed on specific level for the purpose of plotting)
After selecting this shape (manually at this point) I actually need to set fence mode to "VOID", as I would like to delete everything that is selected OUTSIDE of the frame
so, I cannot find the fence mode key-in that would switch fence selection to "void"
reason for above manipulations is, that I am trying to select and delete all tag sets that were double-and triple-placed, and to leave only one that is within the plotting frame. the other method of selection ( by "selectby") would not work in this case , as these tagsets are completely identical, and I will not be able to separate them by properties.
Thank you!
using: AECOSIM Buiding Designer V8i (Select Series 6)
Version 08.11.09.866
  • Andrew, thank you for a great answer, that is what I was looking to accomplish!
  • Lorys,
    this is what the macro shows:
    Sub main
    Dim startPoint As MbePoint
    Dim point As MbePoint, point2 As MbePoint
    ' Start a command
    MbeSendCommand "PLACE FENCE ICON "
    ' Set a variable associated with a dialog box
    MbeSetAppVariable "", "tcb->msToolSettings.fence.placeMode", 3&
    MbeSendCommand "LOCK FENCE VOID OUTSIDE "
    ' Coordinates are in master units
    startPoint.x = -126.675673#
    startPoint.y = 545.974555#
    startPoint.z = 5.334672#
    ' Send a data point to the current command
    point.x = startPoint.x
    point.y = startPoint.y
    point.z = startPoint.z
    MbeSendDataPoint point, 1%
    point.x = startPoint.x - 61.444942#
    point.y = startPoint.y - 76.834425#
    End Sub
    that would mean, that in order to pick a shape, microstation is actually fetching vertices of that shape from the selection, and then sending them to form the fence.
    that would be something VBA would do, but not a macro.
    Speaking of VBA's, I understand these are not a desirable way of programming automation from this point on for 2 reasons:
    1: they cannot be evoked from Projectwise cloud ( unlike .txt batch files)
    2: they are being phased out by Bentley in all Open technology ( that is a responce from Bentley Support on my inquiry re: VBA's possible hosting on PW)
    so, I think  I will try to select text within the print area somehow else.
    Thank you for suggestion !
  • Dim startPoint As MbePoint
    That's a BASIC macro, not VBA.  Prefer VBA to BASIC.
    I'm not sure what that means.  VBA is part of MicroStation.  A VBA macro is hosted by MicroStation, meaning that it runs in MicroStation's address space on the same processor.
    ProjectWise can't host a MicroStation VBA macro because (a) it's a different process probably on a remote computer and (b) it's not MicroStation.
    Since you're working with the V8i generation it's moot whether VBA is 'desirable' — it's there for you to use now, and it remains in the CONNECT generation.
    Regards, Jon Summers
    LA Solutions
  • Hi Denis,
    FYI You can also use the "fence selection new" keyin to select the elements defined by your fence if that helps.
    Mark
    OpenRoads Designer 2022 R3 (10.12)  |  Microstation 2023.1  |  ProjectWise CE 3.4
  • ProjectWise can't host a VBA macro because it's a different process probably on a remote computer.
    hey Jon, a little off topic but  how can i  make a vba macro run under PW?
    Surely there must  be a way
    Lorys
    click link to PM me
