Is Microstation CONNECT Edition also have command selection by short cut numbering method ?
I am assuming that you are referring to position mapping ? If so yes, this is a user preference go to File> Settings > User > Preferences . In the user preferences dialog box go to the Position Mapping category and make sure that the two settings are checked.
Use Position Mapping
Show position mapping aids
Answer Verified By: Sojo Varghese
Hi, that solution (also described https://communities.bentley.com/products/microstation/w/microstation__wiki/36009/how-to-enable-v8i-keyboard-shortcuts-on-microstation-connect-edition) seems to be removed from U12. Where can I find it? At least I cannot find it in dialog below.
Best regards, Wojtek
SW: Promis.e 08.11.13.96/23.00.00.46
Hi Wojtek,
I guess it would be better to ask in a new post. This is 4 months old discussion about something different!
WojtekM said: At least I cannot find it in dialog below.
I see Position Mapping category in my MicroStation CE Update 12 installation.
It's mentioned in MicroStation help that this category is controled by MS_POSITIONMAPPING_CONFIGURATION configuration variable. Can you check how the variable is set?
Also, because it seems you are using not default upf file (the name is derived from Windows user, which I guess is not Personal.MicroSation), can you try to delete it (or rename) to force MicroStation to create a new file?
With regards,
Jan
Hi Jan,
thanks for your reply.
Jan Šlegr said:I guess it would be better to ask in a new post. This is 4 months old discussion about something different!
Sorry if I had a misunderstanding, but that discussion was about keyboard shortcut and enabling position mapping, and that's exactly what I wanted to ask about :-)
Anyway, I forgot to mention that I am testing just released Promis.e Microstation Mode, which is based on PowerPlatform U12. My experience in pure CAD platform question is, that's better to ask Microstation specialsts, not in a product-based forum. That's why I am asking here.
In clean installation, I cannot see MS_POSITIONMAPPING_CONFIGURATION variable at all (. I have tried to manually set MS_POSITIONMAPPING_CONFIGURATION=1 variable in standards.cfg and I am able to see that variable exist and is set to 1, but I am not getting desired result (PositionMapping still not showing). I will fill SR for that.
All the best,
Wojtek
