MicroStation V8i SS4, V08.11.09.829
Is there a key-in to toggle the "lock" on the Manipulate Scale dialog?
I recorded a macro, but it did not record anything for when I toggled the lock.
Brian L.
did you try to make a VBA macro and select object first then use the icon for scale and change the lock to open....?
Worked for me but it looks like its " tbc" thing to hard for simple keyin, so easy answer is yes make a vba macro and it works with a bit of real vba skill you could have it ask you the values ....
Lorys
Hi Brian,
it should be
set item toolsettings proportionaltoggle=<0|1>
but it seems it does not work.
With regards,
Jan
Lorys said:did you try to make a VBA macro
Brian wrote in his question that he tried to record macro ;-)
Hi Lorys, As I said, I recorded a macro, I guess I should have specified a vba macro, and it recorded nothing when I toggled the lock.
If you have code that functions, please share.
Thank you,
Hi Jan, proportionaltoggle is not the code for the lock.
If you toggle the Method from Active Scale to 3 points, a Proportional setting appears on the dialog.
The proportionaltoggle key in, checks and unchecks the box for this setting.
I forgot to mention in my original post that I had tested those set item toolsettings as well.
