I'm trying to build a parametric helix stair finally giving the parametric solids functionality a go but getting frustrated since it seems relevant functionality is missing or tools do not work as expected.
3.1. Unfortunately the "helix curve" tool is not parametric and therefore it won't be possible to parametrically control the geometry of the stairs or enter the values when placing as a parametric cell.
3.1 Have nevertheless drawn a helix using the "helix curve" tool and then using it as the path for the array "along path" method with "rotate" ticked. I'm getting odd results with the treads rotating in an unpredictable fashion. (see image blue)
3.2 When using the same parametric solid, the same helix curve, and the same number of array elements with the standard (non-parametric) polar array tool the result is as expected and the treads rotate consistently and remain horizontal. (See image red)
4.1 Have used the helix feature tool to draw the stair's helix stringers and then use the technology preview "associative extraction" to extract one of the helical edges as a curve to use for the array "along path" method. This actually allows to modify the parametric array path by changing the parameters of the "helix feature" but there are two big drawbacks: First I'm getting the unexpected result described in 3.1 and second the feature modeling is a "legacy" technology and I think doesn't allow to use local variables as inputs to control the parameters of the feature model or use as a parametric cell etc. Without a "parametric" helix solid tool or "parametric" helix curve ( with parameters controllable via local variables) I do not see a way to model the needed stair stringers, railings etc.
The new parametric modeling, constraints tools are very promising and could be incredibly powerful but its functionality is still lacking a lot. While tools and technologies (feature solids, Dimension Driven Design (DDD) are now deemed as "legacy" , equivalent functionality hasn't been incorporated to the new parametric tools. Combining all the DDD's and feature solid modeling functionality under the new parametric modeling approach will bring endless possibilities.
I would appreciate any advice on how to achieve what I'm intending with the helix stairs without having to resort to GC. It may be I'm missing a workaround to these issues.
José
Hi Jose, making our curve tool parametric s something we have in our backlog, together with improving our array tool. Could you share your dgn file with Dinesh so that we can investigate why the current behaviour of the parametric array tool differs from the legacy one?
Thanks Dinesh and Marco.
Have just uploaded Helix_Stair_parametric_Array_Issues.dgn to the Bentley Secure File Upload platform
Best
Jose
Parametric Array Tool differs from Legacy Tool in many ways...primarily when we are not able to capture Number and Distance values during Runtime. As Marco said, Array Tool enhancements are in backlogs and also need improvement to work with 3D Curves used as a Path Element....I have reported Defect-976595 to track the same.
Dinesh
