Does anyone have a Solid Working Area file that works in CE ie SWA.ma
Ian
Ian Lapper said:Solid Working Area
What does SWA.ma do for MicroStation V8?
Hi Jon
It places a temporary 3d cude that is the size of the solid working area, so you can see if your data is outside it or not. once loaded you then unload it
Hi Ian,
I do not think there is anything similar in CONNECT yet. This Enhancement 813283 : Incorporate SWA.MA as a platform tool and add to the Ribbon was filed in January this year.
Maria
Thank you for the update. As we are working on a vast amount of 3d models for infrastructure projects in CE. I need to check the files for SWA issue. Thus, I really need this ASAP.
When can it be made available?
hi Ian,
I follow up with you via SR.
