I was doing an "extend line" command in a 2D file when this suddenly appeared. What would cause it, and how do I debug it?
It corrected itself when I did a refresh view. The black dots appeared as I moved my mouse. I'm using an AMD FirePro W5000 video card with the 2018.Q4 drivers.
--Thanks,--Robert Arnold
This looks like it could be a graphics driver issue ? Have you updated your drivers recently ?
Paul Chater
I'm seeing similar with an AMD Radeon R9 2000 series card.
Yes, I updated my AMD video card driver. I don't know if this is related to CE11, or to the video card driver.
The reason that I have an AMD video card is because Microstation had so many problems with the nVidia drivers. Is it going to be that Microstation is not going to play well with the AMD drivers as well?
--Thanks,--Robert
Tried with my (quite old but still good enough ;-) Radeon R7 370, the latest drivers Adrenalin Edition 18.12.1.1 Optional and everything seems to be fine.
Can you share your design file to try exactly the same data?
Jan
Hi Jan,
So far it has been a once or twice occurrence. I can not reproduce it on demand.
--Robert
