since yesterday I have problem with my PM shortcuts. suddenly the basic shortcuts (meaning tools invoked by 1 - 9) stopped to work. all other shortcuts (alpha characters) work as expected. turning PM off and on in Preferences doesn't help. any idea what might happened? or how to resolve this? is there a config file that is controlling PM shortcuts?Win10 64bit ENthanks
Possibly too obvious a question but have the got the drawing workflow selected rather than task navigation?
Wondering if [Dialog] was set from [Preferences > Task Navigation > Presentation]? To make it enabled, set MS_TASKNAVIGATION_CONFIGURATION = 1.
Answer Verified By: Peter Tegza
thank you! it was set to ComboBox. once I set it back to Dialog, the basic shortcut set works again. btw, it seems to be somehow connected to Main Toolbar, as when I experimented later with various options of this (setting Presentation to all different options), once the Main toolbar is loaded / open the basic shortcut set is working. once it is closed, it does not ...anyway, thanks for pointing me into right direction
/pt
