If I attempt to place text or edit text in the attached file, MicroStation crashes.
ExampleTextFields.dgn
This is a new DGN file, created from the delivered 2D metric seed. When I click the Place Text tool button, I see a ghosted Tool Settings box, then a crash dialog with Abort etc. buttons. Then MicroStation quits. I attempted to create a crash log, but since MicroStation quits on that as well I don't know if there's any evidence!
Is there anything wrong with that file?
Hi Jon,
no problem to place text in this file. Because I have not your workspace, "no workspace / workset" used.
Jan
Jan Ĺ legr said: "no workspace / workset" used
Same here! Thanks for testing.
I'll blame Microsoft Windows updates if I can find no other cause.
Too many things like this happen to me in Update 11. I've rolled back to Update 10.
Rod WingSenior Systems Analyst
I have also tried placing and editing text in "no workspace/workset" environment but could not reproduce the crash.
Can you provide a screenshot of the crash that you are receiving?
Regie
Reginald Wallace said:Can you provide a screenshot of the crash that you are receiving?
The screenshot below was taken shortly after clicking the Place Text button. The Tool Settings dialog is greyed-out and never populates with the dialog item(s) for the tool. A few seconds later, the crash dialog MicroStation CONNECT is not responding pops up. After I click Close the Program the Hang on while Windows reports the problem to Microsoft dialog pops up. Shortly after taking that shot, MicroStation quit without further ado. There was no opportunity to file a crash report with Bentley Systems.
