Dear All,
Could you please help me?
I have a sheet file attached reference (Shade), i want to work through the sheet calling out , but those calling out or label always stay behind the shade that i can not see, even i tried to selected those labels and bring it to front, but it still persist.
Can you help me please?
This appears to be a duplicate of your previous post and has still not supplied details of the version of MicroStation being used.
MicroStation Forum Best Practices
https://communities.bentley.com/products/microstation/f/microstation-forum/172673/call-out-front-of-shade
Could you try changing update sequence from Reference dialog. Open reference dialog, go to Properties & open Update Sequence dialog. Move the Active Design File node to last.
HTH
Mahendra
