I read some information here about certain defects in Connect being on a schedule to be corrected by certain Releases. Is this information published somewhere?
I have used an incredible amount of time filling out Service Tickets, posting questions, reading help files. Those of us using Connect are unpaid beta testers. Since the 1980s I've been a shill for Microstation. This latest software has changed my mind. Microstation Connect is the worst Microstation yet. I can only assume Bentley has moved on and really doesn't care about us lowly CAD users any more.
Hi Bob,
With each subsequent release of MicroStation CONNECT there are issues that are addressed. As with each release we have a listing of all defects that are addressed in that release. i.e. https://communities.bentley.com/products/microstation/w/microstation__wiki/40172/resolved-issue-in-microstation-connect-edition-update-11-10-11-00-36
There is no listing of issues that will be addressed in future releases. If you have want to make an inquiry regarding a specific defect I would recommend following up on that defect through your service request which should be logged against that issue.
Regie
Regie-
That's not what I'd read here before. I have a list too long to post, I'll ask about one- When will we be able to compress without losing raster references?
Reg
What determines which defects/SR you work on for each release?.
Did you report this issue before? Is there any formal Defect number logged for the issue mentioned previously so we can check the status?
Maria Garcia
I believe you referring to Defect 884615 is currently scheduled to be addressed in update 13.
Carl Myhill
Technical Support Engineer
Bentley Systems
