Is there a way to prevent the "Working Scale" dialog from opening whenever a document is opened in Microstation?
Thanks!
That looks like a 3rd party add on. It is probably being loaded from one of your config files or your ucf file with a keyin like 'mdl l workingscale.ma' or something similar. You need to remove that keying from the cfg or ucf file. You should be able to get the name of it from utilities\mdl applications where it will show you the currently loaded mdl apps. BTW please always list the version of Microstation as this helps people answer your question.
