I am using microstation v8i ss4. I want to write a script in a text file (notepad) to place a cell in the drawing but I don't know what are the shortforms or key-ins are to be written to execute the file?
Can anybody help me from where can I get the list of shortforms or key-ins to write a script. Please see the below snapshot. I have written a script but it doesn't work. Can anybody help me what should be script be like?
Narayan
Thanks for your reply rod. I want to one thing. From where did you get the abbreviation "AC" for placing active cell . Is there any list of abbreviations for other commands of MicroStation? From where do I get that?
In the help if you go the the tool index and look up for example cells you will get a list of keyins for that command.
Narayan Kavinatamai said:Is there any list of abbreviations for other commands of MicroStation?
I recommend that you use the full key-in in your script file. The abbreviated commands exist to make experienced users faster.
If you use the full key-in in your script it becomes easier to maintain. Six months from now, you'll look at your script and ask yourself "What does AC mean?" If you use the full command it will be simpler to understand.
Yes In the MicroStation Help there is a Key in index that list all of the current MicroStation key-ins
Help > Contents > MicroStation V8i Help key-in index
