Dear.
I want to do a batch process that does the following.create a fenceChange the color of the objects in the fence.I do not know how to finish the script.
active color 3
PLACe FENCE
XY=0.0179,0.0284
XY=0.5770,0.4950
fence change color
I have to press the left button on the screen to finish it.
regard
What happens if you place a line that says something like "XY=0,0" after your "fence change color" command?
MaryB
Miguel,
If you enter DL= it places a data point at the position of the most recent data point or tentative point.
Regards,Ron
The following Askinga Article might be of assistance in what to place at the end of your script to finish it cleanly.
https://communities.bentley.com/communities/other_communities/askinga/w/askinga/1194/something-neat-to-add-to-the-end-of-script-files
RESETNULLm,erSCRIPT COMPLETE
Thanks Ron. is ok.
thanks
