Hi all,
I have cut a section through a 3d model. I would like to set different depths of view along the cut line. is this possible?
My colleague does this more or less on a daily basis in V8i SS4. When placing the section line just hold down CTRL while putting as many vertices for the cut line as needed. You can adjust these later to your needs. But mind you, there will be a line at each "depth jump" showing an edge where there actually isn't one.
Answer Verified By: Euan Rankin
