Gaps in Dynamic Sections
Hi All,
I am currently cutting a number of sections through a 3d model.
i have discovered the gap command which i think will help me
However i cant seem to see any difference in the section once i create a gap.
would somebody be able to assist ?
  • Hi Euan,
    Please follow Forum Best Practices and help us help you. What version are you using of Microstation?
    if V8i it's in the form of 08.xx.xx.xx If working with Connect Edition it's in the form of 10.xx.xx.xx
    The clip was created and place under a Saved View before you discover the gap command?
    If so and you didn't place a check mark in Associative Clip Volume  in the Create Saved View dialog you don't get to see the modifications you make after to your clip element.
    Hope this helps.
    José
    Answer Verified By: Euan Rankin
