VBA interface error: failed creating the comp manager - 0x80040583
WSDOT loaded their Resources to my machine so I could use the WSDOT environment but when I started to use the WSDOT "Custom Tools" it did not work and have the ERROR listed above. WSDOT told me to ask this question to Bentley to correct the error. What is your opinion to solve this. Hermi Bella 206-363-1675 bellahermi@yahoo.com
What version (e.g. v10.x.y.z) of MicroStation, or other product, are you using?
Herminigildo Bella said:WSDOT loaded their Resources to my machine so I could use the WSDOT environment
Possibly the WSDOT configuration is incorrect.
Herminigildo Bella said:WSDOT told me to ask this question to Bentley to correct the error
You've posted to the Be Communities MicroStation Forum, not Bentley Systems. Here you will receive peer help, with sometimes some help from Bentley Systems staff. It's not a way to lodge a formal support request. However, no-one can solve a problem that may have been caused by the WSDOT configuration if it was incorrectly installed.
Herminigildo Bella said:VBA interface error: failed creating the comp manager
For example, I have no idea what the 'comp manager' might be. I could be wrong, but I don't think that it's part of MicroStation VBA.
Hermi Bella
CADD TECH, LLC
Tel: 206-363-1675
As noted on the WSDOT Website (www.wsdot.wa.gov/.../default.htm) the WSDOT production MicroStation version is V8i SS3. WSDOT resources are not intended for use with SS4.
For the record, this issue was not related to the WSDOT environment. The customer was under the impression that the pre-requisite pack components were bundled with MicroStation SS4 and did not need to be installed separately per earlier versions. We confirmed the issue using the vendor software without WSDOT resources applied (see troubleshooting steps below).
Per a previous forum entry (https://communities.bentley.com/products/microstation/w/microstation__wiki/10631/vba-interface-error-failed-creating-the-comp-manager---0x80040583), the solution was to install the pre-requisite pack. We installed the SS3 pre-requirements pack and it resolved the issue.
Troubleshooting steps (MS V8i SS3 and SS4 used and confirmed):
VBA Interface Error: failed creating the comp manager - 0x80040583 occurs.
Thanks!
