CI_EN_02_11_002.dgn
Check the following Wiki.
Missing Fonthttps://communities.bentley.com/products/microstation/w/microstation__wiki/14552/missing-font
Are you using the RTA configuration. Check with you Administrator to copy the required fonts (RSC) in the right folder as mentioned in the Wiki.
What version of MicroStation (e.g. v10.x.y.z) or other product are you using?
I don't see any text using those exotic fonts in the DGN file that you posted. However, there is a missing reference. Are those fonts used in the reference?
Many of those TrueType libraries are different language fonts. Are you really using text in multiple languages?
