CHANGE COORDINATE SYSTEM IN MULTIPLE DRAWINGS AT ONCE
Is there any way to change the coordinate system to a complete set of drawings?
I have an old project in a coordinate system A and I need to change all of its main drawings to a coordinate system B.
You can do it one at a time, but it is very slow.
Does anybody have any suggestions?
The drawings are in dwg.
Thank you.
  • Hi Adif,
    1. Edit attached ‘Change_ACS.txt’ file
    2. Rename word ‘New’ to your desired existing ACS name. (that ACS should be available in your each dgn file)
    3. Save the file and close.
    1. In MicroStation, go to menu File> Tools> Batch Process.
    2. Click on ‘Add Files or Directories to Process’ button.
    3. Select all files in which you want to change the ACS.
    4. Click on ‘…’ button (Browse for command file) > select attached .txt file.
    5. Click on ‘Process Batch Process Job’ button> click ‘Process’
    This will change ACS in all selected files.
    acs activate all New
    filedesign
    HTH,
    Manoj
    This is a test
  • But is that going to change the CGS and projection?
    Lorys
    click link to PM me
  • No, above command in .txt file is for ACS only. Adlf is asking for changing Coordinate System (ACS) in multiple files.
    This is a test
  • ACS, GCS - they are both called "Coordinate systems". And the solution for one is not the solution for another. Applying an ACS solution when the GCS is the problem could probably destroy a project.
    MaryB
    Power GeoPak 08.11.09.918
    Power InRoads 08.11.09.918
    OpenRoads Designer 2021 R2
  • It sure will, in particular if you need to share data or use any georeferenced information.
  • Oh okay, if that is related to GCS then...
    1. Invoke GCS Library > select desired GCS from the list and ‘Copy’ its name properly from the right pane.
    2. Open attached txt file, delete all previous content and just keep below line in it…
    geocoordinate assign noquery GCSNAME
    1. Replace GCSNAME in above line by GCS name you’ve copied.
    2. Save and close the file.
    5. Follow the same procedure from Step-4 as mentioned in my first reply.
    Manoj
    This is a test
  • Manoj,
    This is useful to know. In addition to this is there a key-in that will allow updating to a GCS transform?
    Up till now I create macros to do the same, however, macro recorder does not recognise actions in the GCS dialog, to this end I have had to use the method of get GCS from file and point to a file with the correct GCS or Transform attached.
    In U11 we can now name transforms, which is great, is it possilbe to save transforms as GCS rather than storing in files only?
Reply
  • Manoj,
