It sure will, in particular if you need to share data or use any georeferenced information.
Oh okay, if that is related to GCS then...
geocoordinate assign noquery GCSNAME
5. Follow the same procedure from Step-4 as mentioned in my first reply.
Manoj
If my reply answers your query then please click on 'Verify Answer' button in my post.
Thanks for reporting,
Manoj,
This is useful to know. In addition to this is there a key-in that will allow updating to a GCS transform?
Up till now I create macros to do the same, however, macro recorder does not recognise actions in the GCS dialog, to this end I have had to use the method of get GCS from file and point to a file with the correct GCS or Transform attached.
In U11 we can now name transforms, which is great, is it possilbe to save transforms as GCS rather than storing in files only?
that wont work it just renames the GCS to another name datum projection it wont reproject the data in the design file will it?
If I had just one file I would reapply the new projection thru the GCS tools and accept the reproject option when it pops.
ok I figured it out its
geocoordinate assign reproject NEWGCSNAME
Example
my old file is MGA94-55
I want to change it to MGA94-55 and reproject it
the key in is
geocoordinate assign reproject MGA94-54 ( as it was named in the GCS tool window must letter perfect)
geocoordinate assign reproject MGA94-54; FIT VIEW EXTENDED
and yep it reprojects without going to the CGS tools to do it!
Lorys
