Hi all,
I have cut a number of sections in a 3d model. i then wanted to re name all of the sections so done this in the models tab. however when i highlight the section mark it still has the original name assosiated to it.
Is there a way i can change the name of the sections?
If so this would save me a significant amount of time as i wouldnt have to re cut all of my sections.
Many thanks,
Euan Rankin
Hi Euan,
Section marker shows name of a saved view. this saved view is then placed on drawing or sheet models. renaming drawing or sheet model is not going to rename saved view.
In your case you should try to rename the saved view.
Let me know if this works for you.
