Hi everyone,
We have a reoccurring problem in the office which none of us have been able to resolve.
When using the Stretch Elements command, some elements don't stretch at all. It seems to be a fairly random selection of elements that don't stretch. For example some groups and cells stretch, but not others. Some lines don't stretch and sometimes whole shapes or groups just get left behind. When none of the elements stretch we get the message "X No Elements in fence" in the message centre.
There is a similar issue with the selection tool (not sure if it's related) where some lines / groups of lines have to be selected one at a time as the selection tool misses them.
Has anyone encountered this issue? Any solutions?
Alex
We are using:
Micro Station Power Draft Connect - Update 10 Version 10.10.00.23
And we are running on various Windows 10 computers.
Great Example Ian, this perfectly illustrates the problem we are having!
Here is hoping for a solution. As you said, its deeply frustrating!
Was there ever a solution for this. I seem to be having the same issue with a file.
Hi Duncan
Not had any response in respect of this issue.
Have to say it hasn't happen recently and with it not being file specific, it is difficult to replicate or work out why it happens
Ian
currently using OBD 10.10.01.151
Thanks Ian
It seems to be inconsistent and quite random but really annoying.
Hi Alex,
To investigate this issue properly, we need a test data from you and steps in detail to reproduce.
Thanks for reporting,
Manoj
