Dear Forum,Fit Reference key in seems like a very useful command, as per this post i found:https://communities.bentley.com/products/microstation/f/z_-archived-microstation-v8i-forum/85614/zoom-to-referencefileI cant get this to work on MS SS3 V8i with ref file nest 1. Any issues with Nest Refs on this command? Any work round?Or am i using it wrong, or is there a better command to use?
Does that fit the highlighted reference, considering i have 300 or so? I Thought that fitted 'all references', i may be mistaken...
No that's all refs. I've tired the 'reference fit;point absolute' in SS3 and that seems to be working for me.
Answer Verified By: andihawes
what does 'point absolute' do? Does it fit highlighted ref? Ive just tried it and it does!!! Never knew that
just tried this and while it does work: a Design in a Nest highlighted and this command applied shows the whole Nest Set, not just the one i have highlighted.Anhy ideas?If i could get the Reference Fit Logical Name to work i could use that but currently with the Nest i cannot copy paste logical names [which are quite long] as the Attachment Dialog is greyed out Nested Designs. Would be handy to know of a configuration change which could 'ungrey' this box??
