I have Microstation Connect and so far, the only way I have found to launch the plugin AutoTURN is to type "Path" (or another AT command) in the Search box. I know there has to be a better way to launch the plugin. When we had V8i it was located in MSAdditions but there doesn't seem to be that option for Connect. Thanks!
And remember: AutoTurn only works in the full Microstation CE, not in Powerdraft CE. One of the reasons for keeping a Powerdraft V8i version...
Have you checked to see that the unload command actually works? I'm not sure it does, at least not sufficiently to release the license. If you investigate carefully, you may find that the interface is unleaded but the license is still be consumed. Of course, this only matters if you have a limited pool of AutoTurn licenses.
Please note that I used terms "may", "not sure", etc. I don't know if this applies to AutoTurn, but I have seen it with other software.
Robert Garrett
Hi Robert,
Thankfully it does. Good point though - ive found that issue when testing out some custom apps with the SDK. It is very frustrating at times...
Mark
OpenRoads Designer 2022 R1 (10.11) | Microstation CE Update 17.2 | ProjectWise CE 3.4
Mark Shamoun said:some custom app
Apps written using .NET don't unload. They remain in memory until you exit MicroStation. It's a feature of .NET, not MicroStation.
That they remain in memory can cause puzzling issues when you reload the same app using MDL LOAD XYZ a second time.
MDL LOAD XYZ
Apps written using native code (i.e. C++) behave as one expects. MDL UNLOAD ABC really unloads the DLL from memory.
MDL UNLOAD ABC
Hi, I tried the unload and although it removed from the MDL app list the AutoTurn menu remains and if clicked on then the app relaunches.
Has anyone found a way to truly unload? or is it not possible?
