When exporting to kmz/kml certain linestyles come in with "Style#'s. Anyone seen this? How can you get rid of them?
Which software / version is being used for this operation? Please follow the MicroStation Forum best practices to ensure all the relevant details have been provided to assist with your issue. Do you have an example this is being exported from? Maybe a workflow with what settings have been selected for the tools being used.
Connect v10.11.0.36 u11
assign a coordinate system using "Geographic Coordinate System"
choose FL83/2011-EF
go to File, Export, Vizualization, Google Earth, and then save.
Google Earth opens and the linework appears with "Style#'s" at the end of each element.
It seems to be happening with one particular file since I've created many other kml's with no problem.
I have found a work-around in Google Earth by right clicking the style symbol, going to placemark properties, and choosing "No Icon" for each of the various style placemarks.
Hi Andrew,
Can you please share the dgn in which you are facing this problem? I remember if there are points in your dgn then each point will be shown as a Placemark after exporting.
Manoj
Where should I upload the file?
Click 'Reply'> Insert> Insert image/video/file/ > From: 'File Upload' > 'Browse' your .dgn file> Ok
4214.temp.dgn
