Hi guys,
We recently upgraded some of our users to Microstation SELECT Series 4.
One of our users tried to edit a tag element. Here is the Edit Tag dialog before the edit:
The DRAWING_TYPE value displays correctly from right to left.
After I mark part of the text for editing the dialog looks like this:
As you can see the value field is garbled and becomes unreadable. So I cannot mark and edit the tag value.
This occurs also in the Microstation key-in field:
So it appears to be a general Microstation issue. In SELECT Series 3 everything works as expected.
Any suggestions?
Benzi
Here is a screen shot from AutoCAD 2013.
Notice how the selected text in blue leaves the underlying letters intact. So you can mark a single letter for editing.
In Microstation SS4 the underlying Hebrew letters get garbled when you mark them for editing. I checked the issue
in the CONNECT edition of Microstation and the same issue is also there.
Here are Arabic and Greek in AutoCAD 2013. Letters remain intact after marking text:
So something is definitely different in the way Microstation interacts with Windows.
Hi Benzi,
Following Defects have been logged...V8i: Defect 1002067:Tag value getting changed after selecting it.Connect: Defect 1002075:Tag value getting changed after selecting it.
For the text mirroring, following workaround is provided
Hebrew text, inside Word Processor is mirrored
