With CE U11 I have noticed that when save-as ing a file, the new file opens as read only. dgn or dwg???
is this a setting or just a bug?
I have had a few users now who have not realised this and have carried on working, and for some reason have been able to make changes to the new models, which obviously do not save.
It's not doing that for me in U11. Saved as file is editable.
Thanks for confirming Duncan. must be a setting then. will dig
not sure what though. Can't see anything in the Save As options that would make it read only and can't find a variable that would either. Be interested to know the answer.
Hi Duncan,Perhaps you could try checking the following forum:https://communities.bentley.com/products/microstation/f/microstation-forum/171713/read-only-is-permanently-on/494877#494877Regards,Robert
I'm struggling a bit to pin down what is causing this. I am not finding consistent behavior, happening on some files but not others.
Trying to find the common theme between the different files. It's just strange.
