Just starting using CONNECT this week. I see there is a tool for importing KML files.
Clicking on the icon
I get the following error
I've been dabbling with the user configuration files. Mapping resources etc.
Any ideas?
Would you be able to clarify which software you are using and exactly what you are wanting to perform.
Hello Andrew,
I'm using CONNECT Update 10 10.10.00.23. I would like to import Google Earth KML files to my DGN.
Cliff,
That is a TopoDOT feature. If you start TopoDOT, they Import KML button should work properly.
Answer Verified By: cliff
That worked. Thank you Maury.
No problem. I will update our software so that it does not show up unless it is loaded
Thanks for pointing it out
