After setting Tentative to the centre button (wheel press) and closing the smaller window,
the Button Assignment window will not close. Presses of ok and cancel are ignored.
When another window is clicked, the BA window sometimes shakes, as if it were waiting
for an input. Which cannot be made. No other window can be found for which the shaking
one is waiting.
This is file independent. I have to use Task Manager to kill uStn. This is now hard on,
I have tried maybe 6 times or more; it will not recover from setting T to wheel.
thanks for any help
Jim
thanks sorry about this piecemeal
the menu 'button mappings' comes after button assignment
unwanted file open dialog also appears after file open from shortcut fails because
i have that one already open
