I've been away from a Microstation environment for a little while and have recently returned to find (& become very frustrated) that the "Trim Quick" (aka Intelli-trim) commands no longer work. I'm sure they weren't hurting anyone. Obviously whoever removed them had never used them. Those of us who explore the benefits of every tool did use them.
Can these go back Please?? Removing Intelli-trim was not an Intelli-gent decision.
Please refer to the following article:
https://communities.bentley.com/products/microstation/f/microstation-forum/118519/intellitrim-and-quicktrim
The "Trim Multiple" tool replaced intellitrim.
You can select multiple cutting edges by holding down the ctrl key and select multiple elements to trim by holding down the primary mouse button to draw a selection line.
Answer Verified By: Dennis Barker
Thanks David. Good to see it is still there in finction if not name.
I did a couple of searches for Intelli-trim but it didn't give me that thread for some reason.
I just installed v8i ss4, holding down control key select multiple is not available, drawing a fence line to select the trim elements also not available, select all cutting elements is not available...
the tool setting dialog window does not have the additional command icons, i.e. multitrim, etc... -i also do not have the option to pin or unpin the task tool dialog, not sure if this is affecting anything. -if i am in the trim command, i cannot draw a fence to select all the lines to be trimed, also i cannot use control key to select two cutting lines as show in the tutorial... -in the trim elements command, i am not able to select everything as cutting edge... - also in the copy/move parallel command, I am not able to see additional icons such as select portion of the element... i have the same verison of v8i as my coworkers, but they do not have this problem... does this happened to anyone using microstation? could you please help? really appreciated!
