I have a wacom tablet intuos and when I use the scroll function of 2 fingers moving up and down it seems difficult to get an accurate zoom like I do with a standard mouse wheel. I would like to try the wacom zoom feature where you can pinch similar to an iphone, any ideas on how to get the zoom feature to zoom in and out in Microstation?
Thank you for any ideas.
-Dan
Also would love to be able to use 4 finger touch to pan.
If you are using intuos4, there is an option button to toggle Zoom In and Out feature by using one finger to clockwise and counter clockwise. Here enclosed an image for your reference. Of course, you will have to define your focus point by the pan before doing that.
Hope this helps,
Hyung
I contacted Wacom and they said I have a 2013 version, not sure what that meant but I asked them if I have the circular zoom capability and they took me to the area where you check for the pinch zoom. They didn't understand very well. With the pinch zoom when I go into Microstation and try and use it, it says "3D-only tool" when in a 2D file, so whatever the pinch does it must correspond to a 3d command.
I do not know what type of device you are using. However, the pinch functionality that you are trying to do can be also performed in the pad which I marked in white rectangle no matter whether you are in 2D or 3D. Here enclosed another image you can refer. The device is based on Intuos Pro M.
