Experienced AutoCAD user, newbie Microstation user here.
Opening up MS shows this kind of "Open" file directory box.
How can I make it look more normal, like any other Windows program, or AutoCAD, below?
Daniel Bhaumik said:Opening up MS
What version (e.g. v10.x.y.z) of MicroStation, or other product, are you using?
Oh, should have mentioned - V8i (SELECTseries 3).
Try to go inside Workspace \ Preferences \ Look and Feel \ Use Windows File Open Dialog:
If that don't help, you can always try and use the restore factory defaults.
Hope this helps & regards
José
