I have just upgraded from V8I select series 2 to 3. Before, I could move or copy an object, drag it to any distance and I would get a repeating snap for the distance. Now, I cannot get that repeating snap unless I type a specific distance. AccuDraw and AccuSnap are on. I can draw lines and get repeating distances without key-in but it doesn't work for move or copy any more.
Go to your Accudraw Settings (GS), Floating Origin needs on
Bob, my Floating Origin was already turned on.
I think this is what you are looking for
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
My settings look the same there as well.
Perhaps some screenshots of all the tabs in you AccuDraw settings dialog would be helpful?
