I have a B-spline drawing of a mountain road. How do I display the dimension of this curvy road such that the dimension annotation follows the curves (similar to how the parallel tool works, but for dimensions). Microstation V8i (series 4). Dimension element doesn't work here. Dimension Linear and Dimension Angular didn't allow me to do this either.
I don't believe there is a dimension tool (as delivered) that will do that.
I would cobble up something that looked good out of another copy of the B-spline and a text field for the element length. But it wouldn't be a dimension.
MaryB
Sorry, this type of dimension tool is not available in MicroStation. We have similar annotation in OpenRoads.
Thanks for your suggestion. . It has been filed as an Enhancement 1005230
Manoj
